Chevy84camaro
- Joined
- Apr 26, 2020
- Messages
- 5
Ok everyone I bought a bobcat 731 it worked fine for a while but after a while I found that the drives where a little noisy so. I check my hydraulic fluid and realized I lost the cap to the hydraulic. Noticed fluid had water in it so flushed system clean. cleaned bronze filter in middle 3 hoses it was dirty. Are there any others? Also ran skid steer after replacing cap and new filter and new fluid had hydraulic on one side then lost it on that side got the other side. First right side worked then left side worked but lost most right side. Thought maybe had still more water or dirt in filter so drain again cleaning filter and changed filter new fluid again started over now drives no movement at all or noise thinking I missed bronze filter somewhere or not filling it up the whole way with hydraulic fluid somehow. I do have lift and tilt they work great better than before changing oil. Just haven’t had drives right after oil change. Even when they worked after oil change not enough to go up hill. So is there prime method I’m not doing? Also noticed hydraulic filter wich I filled with oil before restart when I take it of it’s only like 3/4 full of oil after running machine. Seems like oil not returning to hydraulic filter enough
