Hello, I have a skid loader with a Kubota V1902B motor in it. I believe that I have a bad head gasket or maybe even a cracked head. What is the easiest way to verify one or the other, and the steps to remove just what I need to and not the whole thing…
Also if you know where I can buy the needed gaskets, and or cylinder head if needed. The reason I think it’s the head gasket is that, with the exhaust manifold removed and cranking the motor over the second exhaust port from the pulley is pumping antifreeze out of the port. Does anyone have a detailed assembly instuctions with torque setting and the order of torqueing? Thanks, brew
