tymwltl
- Joined
- Dec 22, 2015
- Messages
- 1
Has anyone had an issue with the injectors not seated down in the head of a V3300-T engine? The hold down plates that secure the injectors down into the head seem to not be holding the injectors down solid against the sealing washers. We are getting compression blow by up the side of three injectors under the valve cover. Has anyone had this issue and if so what did you do to make it right again? Is there an issue with the hold down clamps used to hold the injectors in the head ? [email protected]
