Bobcat Skidsteer Forums
Bizarre ! Loader arms lift when off
Reply to thread
Message
<blockquote data-quote="Fishfiles" data-source="post: 67211" data-attributes="member: 782"><p>that could be your problem , if the detent won't engage then the ball and spring must have jump out the detent collar and has the spool off centered , I have had to change quite a few of the detent collars because the groove inside gets worn out and the ball will jump out the spool , I have tried to do it without pulling the spool out the valve, but I couldn't get it , you need to pull the spool to fix that , the collar is the part that the e clip on back the cap hooks to</p></blockquote><p></p>
[QUOTE="Fishfiles, post: 67211, member: 782"] that could be your problem , if the detent won't engage then the ball and spring must have jump out the detent collar and has the spool off centered , I have had to change quite a few of the detent collars because the groove inside gets worn out and the ball will jump out the spool , I have tried to do it without pulling the spool out the valve, but I couldn't get it , you need to pull the spool to fix that , the collar is the part that the e clip on back the cap hooks to [/QUOTE]
Verification
Post reply
