Bibcat fuel issue
metsin032000
Good morning I have a 2018 t595 that went full speed off a 12in drop and broke the tubes off going into the tank I replaced it but the machine runs rough and puffs black smoke a lot any help is appreciated,It will start but makes a knocking sound only 800 hrs on the machine thanks for any suggestions
Reply
Report
Here is kind of a blanket statement:
Black smoke is caused by too much fuel and not enough air.
Most common causes of black smoke are faulty injectors, a faulty injector pump, a bad air filter (causing not enough oxygen to be supplied).
An injector problem could also cause the knocking sound.
If you landed hard enough to break tubes coming out of the fuel tank, who knows what else may be broken? Hope this helps.
