foton
I believe that I have the same model as (determining model post) yes I do not know exactly what I have either. But one problem that I have is that I get sparks between the engine and the inner half of the cvt pulley, when I use the cvt speed increasing cylinder . When I had the engine out the outer half came right off . The inner I put a 3 jaw puller on snugged it up tapped it tightened some more ,ended up cracking it so I welded it up and left it alone. Is there a trick to getting one of these off, it looks like it is just on a keyway. Does anyone know of a vintage skid steer bone yard that might have a replacement in case I have to cut it off if it is welded it self to the crank. Thanks Dave
