Battery light
richbuilt
I had to jumb my 773 it ran aboust 5 minutes and the battery light came on all the control light started bliking and it would not move is the battery bad or is it something else
I would suspect a bad battery as you needed to jump it. It could be the battery or even the alternator not charging or over charging causig the error on the panel.
Personally i would charge the abttery over night and see how it performs in the morning. If it still needs a jump to start, get a new battery.
Something that is not easy to check on these and often gets overlooked is the alternator, as you have to lift the cab to check it out.
I have seen a few with a broken mounting bracket, which slips and throws the belt or even cuts it.
