Bobcat Skidsteer Forums
battery cold cranking amps
Reply to thread
Message
<blockquote data-quote="usa#1" data-source="post: 32272" data-attributes="member: 3516"><p>I believe the Walmart battery will be fine. It's really an exide battery. I've had good luck with an automotive battery in my JD tractor. Anyway the original equipment Bobcat battery only lasted about 3 1/2 years so I will at least get about the same amount of use out of the Walmart unit as the one supplied by Bobcat. Remember Walmart will replace it free of charge for 3 years.</p></blockquote><p></p>
[QUOTE="usa#1, post: 32272, member: 3516"] I believe the Walmart battery will be fine. It's really an exide battery. I've had good luck with an automotive battery in my JD tractor. Anyway the original equipment Bobcat battery only lasted about 3 1/2 years so I will at least get about the same amount of use out of the Walmart unit as the one supplied by Bobcat. Remember Walmart will replace it free of charge for 3 years. [/QUOTE]
Verification
Post reply
