Other Brand Skidsteer Forums
New Holland Skidsteer Forum
Bad Control Valve?
Reply to thread
Message
<blockquote data-quote="bbill" data-source="post: 93960" data-attributes="member: 13396"><p>Thanks for the response. If I to guess why the connecting rod feels "mushy" when moving it, I would say something (hopefully just a disintegrating o-ring) is impeding movement of the spool. I hope nothing in there is scored. The suggestion to raise the arms in case the valve needs to come out is a good one. I not sure I would have thought that far ahead. I'm glad you mentioned how far up the loader has to be in order to remove the tank. I could not find that scanning through previous posts. I'm sure it's there somewhere. I will most likely be back with more questions later. Thanks, Bill</p></blockquote><p></p>
[QUOTE="bbill, post: 93960, member: 13396"] Thanks for the response. If I to guess why the connecting rod feels “mushy” when moving it, I would say something (hopefully just a disintegrating o-ring) is impeding movement of the spool. I hope nothing in there is scored. The suggestion to raise the arms in case the valve needs to come out is a good one. I not sure I would have thought that far ahead. I’m glad you mentioned how far up the loader has to be in order to remove the tank. I could not find that scanning through previous posts. I’m sure it’s there somewhere. I will most likely be back with more questions later. Thanks, Bill [/QUOTE]
Verification
Post reply
Bad Control Valve?
