Other Brand Skidsteer Forums
New Holland Skidsteer Forum
axle metal
Reply to thread
Message
<blockquote data-quote="downrigger" data-source="post: 45638" data-attributes="member: 4980"><p>hello mike.i can see where the sleeve and axle come's together but than about 1/2 in.in from there is this change in the metal it is about 1/4in wide go's all the way around and is a silver gray color and than return to the regular color of metal.it is a perfect band.at frist i though it was some kind of a slip device .don't know .thank's so much for the come back.Jim p.s i will but the factory sleeve on.it had both before who ever did it before just put the thin speedy sleeve on over the factory sleeve.thank you again</p></blockquote><p></p>
[QUOTE="downrigger, post: 45638, member: 4980"] hello mike.i can see where the sleeve and axle come's together but than about 1/2 in.in from there is this change in the metal it is about 1/4in wide go's all the way around and is a silver gray color and than return to the regular color of metal.it is a perfect band.at frist i though it was some kind of a slip device .don't know .thank's so much for the come back.Jim p.s i will but the factory sleeve on.it had both before who ever did it before just put the thin speedy sleeve on over the factory sleeve.thank you again [/QUOTE]
Verification
Post reply
axle metal
