AVS 8410 with a 70" Davco brush cutter
bison
Newby here,Hi to all I got my eye on a used unit. Any body here run a 8410 with a Davco brush cutter? What you think of it,how does it work for clearing out light aspen and willow bush up to 6" ,(most is 1 to 3") thick Is there anything better out there i should look at Thanks
Watch my vid here
http://www.youtube.com/watch?v=i0eWNpMYFYk
It is a low flow brusher running on 15 gpm at 2600 psi. It is a lot lighter duty then what you are looking at. I knocked a lot of 3 and 4" material down and some larger.
6" is pretty big to mow, but I believe those heavy units can do it, if mine can do 4" and some 5"
Also take a look at the new Erskine Quick Attach HD mower http://www.youtube.com/watch?v=7mr3mWtz0QY
Watch my vid here
watching your vid,it looks like identical vegetation to what i need to remove. And yes, the ASV is a far heavier machine than the bobcat,its got a 35 gl/min pump on it,the davco is rated for up to 6". The erskine vid did not want to load
