Auxillary Hydraulic Lines on 853
Rambler
I removed my two lines off the machine this morning, but forgot to take a picture. Both rubber lines come down from the lift arm on the left side of the machine where they both attach to fittings on a bracket. The bracket is located just behind the battery. One hose has a fitting with a 90 degree 1 3/4" long elbow with a nut and the other a 90 degree 3 1/2" long elbow with nut. The elbows then connect to the fittings on the bracket. Does the hose with the 3 1/2" elbow attach to the fitting on the bracket closest to the outside of the machine or the fitting closets to the engine? I tried to post a picture using photo bucket, but could not get it to work. Thank you Greg
