Auxiliary hydraulic control problem
lighthouse
My Bobcat 7753 skid steer recently developed a problem with the auxiliary control switch. it will just suddenly switch direction of the flow and max out and I have to turn off the axillary Hydraulics to get it to stop. I I am pretty sure it is a problem with the flow switch on the steering lever however I cannot figure out how to get it apart. Unfortunately my service manual does not give me instructions as to how to remove it. Any help with telling me how to take that off the steering lever and or any other ideas what that problem could be would be much appreciated
I think you are right about the switch in the handle. Try to pull the rubber sleeve down away from the plastic joystick head and you should the the tab you press and just pull it off. Your wires run thru the center of the tube.
