Asv pt100 injection pump issue?
topfli8979
I've got a weird issue here guys, just bought a 2008 Asv pt100 at auction. The throttle lever on injection was tied with a spring to be advanced fully because the throttle cable is broke. I replaced throttle cable and removed spring to put pump lever back at idle... I can start machine it idles, moving the lever on top of injection pump does not adjust rpms much at all/very minimal. But of I shut engine off tie the throttle lever with spring like it was when I got it. Start engine it will run full bore rpm.. what the heck is going on?
I know almost nothing about that machine. but if it has a mechanical injector pump determine if it has a pump that has a internal pump oil reservoir , if so check the oil level. most are lubed off the engines oil system but not all. I wonder if there is something going on with the governor? good luck
