ASV MD-70 Drive issues
nunolambuca
Having issues with Drive on my MD70
I replaced the tracks lately because they were completly broken. I thought that was the reason I was having issue steering and driving and old tracks would jump teeth and etc.
Got new tracks and I think something is wrong still.
flat, try to drive forward slow.. it moves. I think engine needs some rpm to move but ok. if going uphill just a little, moving straight, needs lot of rom on engine to move or it will stall/die the engine.
My understanding is that if I had seal/pump issues, motor would not die, because oil/fluid would not build up pressure. it would not move.
But the feeling I have is I am driving with e-brake on.
If I try to turn left or right it does it really slow and with lot of rpm needed to be able to do it.
I see 4 hoses going to drive motors. I am assuming 2 large and the drives, another one comes from same location as those 2 large, and the 4th one I am assuming is some kind of return?
I don't see a break, or are those 2 thinner lines the break?
How to debug? Could it be also filters? Which ones?
LIft works fine now.
Thanks
