You can refill the system after draining with green. Bobcat uses the purple stuff solely because it is enveriomentally friendly. Do not do pour straight green coolant and then water thinking it will mix in the machine. Kubota have small coolant passages that straight coolant can clog and cause overheating.I believe you can use any antifreeze in any engine you just can't mix them but let the expert s weigh in
