Another question about Deutz
lesgawlik
I am preparing to replace a glow plug. The engine is a Deutz BF3M1011F. It uses 4 plugs in the head. I read through the manual, and I can't find a spec for the plug. I think it's Deutz 118 0400 or Beru 0100226239. Does this sound right? Any suggestion for sources? If those numbers are right, it's M12x1,25. What reamer should I use? I found this - Hazet Glow Plug Reamer - 12 X 94.5 mm, 55 7871 010, but I don't know if it's the right one? Should I use copper antiseize when I install it?
The first time I did my timing belt, I went by what the Bobcat manual said, about a page and a half of instruction. That did not go well. I found EPU.com and talked to them. They sent me copies of the Deutz manual for changing the timing belt, it was 8 or 9 pages. Went a lot better after that. Call them with your engine model and serial numbers and they will tell you what and how you need to do it. sstec
