Bobcat Skidsteer Forums
Another pivot pin removal question
Reply to thread
Message
<blockquote data-quote="Donnyviking" data-source="post: 88195" data-attributes="member: 12624"><p>Thanks for the information. Yes snap ring was removed. I tried the slide hammer idea. I used brass NPT which was stupid on my part. Broke fitting so drilled out and tapped to 1/2-13 than ran long bolt thru hole. Kept turning bolt until plug was out. Scarred the side of the plate and bore. Lots of dirt in grease. I need to put a plug into the plate to get 1/8 NPT again or just change to a standard thread zerk fitting. Thanks again for the help.</p></blockquote><p></p>
[QUOTE="Donnyviking, post: 88195, member: 12624"] Thanks for the information. Yes snap ring was removed. I tried the slide hammer idea. I used brass NPT which was stupid on my part. Broke fitting so drilled out and tapped to 1/2-13 than ran long bolt thru hole. Kept turning bolt until plug was out. Scarred the side of the plate and bore. Lots of dirt in grease. I need to put a plug into the plate to get 1/8 NPT again or just change to a standard thread zerk fitting. Thanks again for the help. [/QUOTE]
Verification
Post reply
