all steering motion are good but right forward on 743
freitad
but the bobcat was use it good every onces a while would not work but if i jerk it back and forward it would work fine use it yesterday and after 3 hour now i have no right froward movement but have backards both left and right and left forward movement only please help i am good in fixing thinks but have no idea about bobcat's
Hopefully its just a relief valve on the pump. No doubt it will be the one one you can't access easily. Look at the pump, the moddle section where the hoses come out, there will be two large plugs on either side, under here are high pressure relief valves. Check there is no rubbish stuck under it or the spring is not broken.
the big long vavle assbelly between the seat and the back of the motor with large hyd. hose coming out of it ? if so how much will it cost and caN IT BE REBUILD by me and get rebuild gaskets for i did see a litte bite of fluild coming for the right bottom of that valve when sitting in the seat side thanks a lot for helping a gain thanks dan.
I'm talking about the main pump, the blue bit with multiple hoses coming out of it.
Both can be re-built, parts are still available.
