General Skidsteer & Technical Topics
Shop Talk
Air Conditioning
Reply to thread
Message
<blockquote data-quote="OldMachinist" data-source="post: 34420" data-attributes="member: 437"><p>The voltage from the ac button has to pass thru the low pressure switch before it gets to the compressor. Since the compressor isn't kicking on you just need to put a gage on the low pressure side. A typical AC system requires 26-28 psi on the low side before the switch closes and energizes the compressor clutch.</p></blockquote><p></p>
[QUOTE="OldMachinist, post: 34420, member: 437"] The voltage from the ac button has to pass thru the low pressure switch before it gets to the compressor. Since the compressor isn't kicking on you just need to put a gage on the low pressure side. A typical AC system requires 26-28 psi on the low side before the switch closes and energizes the compressor clutch. [/QUOTE]
Verification
Post reply
Shop Talk
Air Conditioning
