Bobcat Skidsteer Forums
Adding AC to a 773G Turbo
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 25986" data-attributes="member: 82"><p>True, but think of the volume you need to cool vs a car? The other thing you need to watch is the car systems are designed so the gas after it leaves the evaporator goes to the pump and cools it. If its not designed correctly your pump can be damaged due to excessive heat. As for air flow for the condenser you only need to use your main cooling fan. You get some decent flow out of it.</p><p>Other machines i have seen it fitted to, the AC unit is actually attached to the top of the ROPS. It looks ugly but obviously works. The condenser and evaporator are built in i believe.</p></blockquote><p></p>
[QUOTE="Tazza, post: 25986, member: 82"] True, but think of the volume you need to cool vs a car? The other thing you need to watch is the car systems are designed so the gas after it leaves the evaporator goes to the pump and cools it. If its not designed correctly your pump can be damaged due to excessive heat. As for air flow for the condenser you only need to use your main cooling fan. You get some decent flow out of it. Other machines i have seen it fitted to, the AC unit is actually attached to the top of the ROPS. It looks ugly but obviously works. The condenser and evaporator are built in i believe. [/QUOTE]
Verification
Post reply
