Other Brand Skidsteer Forums
Caterpillar Skidsteer Forum
adding a/c
Reply to thread
Message
<blockquote data-quote="bobcat_ron" data-source="post: 36087" data-attributes="member: 1066"><p>Better off buying a used unit with A/C, they are a bugger to add the Cat factory A/C kits, you'll be tearing the guts out of the belly of the machine. A better option is a rear mounted Red Dot unit behind the cab rear window.</p></blockquote><p></p>
[QUOTE="bobcat_ron, post: 36087, member: 1066"] Better off buying a used unit with A/C, they are a bugger to add the Cat factory A/C kits, you'll be tearing the guts out of the belly of the machine. A better option is a rear mounted Red Dot unit behind the cab rear window. [/QUOTE]
Verification
Post reply
adding a/c
