Bobcat Skidsteer Forums
A problem with S100 tilt function ( both cylinders come down - pedal in neutral position)
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 57283" data-attributes="member: 82"><p>I too would just do the cylinders. A seal kit depending on where you go will cost you all of $30 each. Then you know they are done and will potentially out last all the work you plan on doing.</p></blockquote><p></p>
[QUOTE="Tazza, post: 57283, member: 82"] I too would just do the cylinders. A seal kit depending on where you go will cost you all of $30 each. Then you know they are done and will potentially out last all the work you plan on doing. [/QUOTE]
Verification
Post reply
