Leifalmundo
- Joined
- Feb 14, 2020
- Messages
- 1
I have the early 963. Noticed the hose running from drive control block to drive pump was leaking so I replaced the 4 hoses, also the test port hoses were leaking so I removed them and put caps on. Filled with 10 gallons AW 32 and started it up. At first it would only go back and forth about 10 feet with one side working better than the other. Now one side has locked up completely but the other side seems to drive normally. I’ve let it idle for over an hour trying to bleed air out of the system but no luck. Is there an air bleed sequence?
