as before i thank you in advance for any help you guys provide. Have this '95 873 that i bought used. I now find a moderate oil leak out the "belly pan" i believe its called. Engine is sideways and from all points of view (which arent many) it seems the leak is from the back side of the oil pan. It almost looks as if the a portion of the oil pan is touching the frame. Maybe rubbed through? I guess my question is whether that pan under the motor is removable and if so is it self explanatory. thank you again
