Bobcat Skidsteer Forums
943 Bucking bronco problem
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 97649" data-attributes="member: 82"><p>Check the linkages between the steering levers and pump, if there is any play in here, it can cause it to buck around.</p><p>Even after years of sitting, it should not buck around when you try and drive it.</p></blockquote><p></p>
[QUOTE="Tazza, post: 97649, member: 82"] Check the linkages between the steering levers and pump, if there is any play in here, it can cause it to buck around. Even after years of sitting, it should not buck around when you try and drive it. [/QUOTE]
Verification
Post reply
