Bobcat Skidsteer Forums
873F head gasket or Turbo problem?
Reply to thread
Message
<blockquote data-quote="Rich M-37" data-source="post: 42662" data-attributes="member: 4397"><p>Shotym2, I had a engine run a way problem with my 873, it turned out to be the diaphram in the fuel pump. It as a scary situation, and possibly a costly one. The oil level in the crankcase raised up to the level of the breather and started to burn the oil and fuel mix. Also engine oil dillution can be a problem. Keep an eye on you oil level. Rich M-37</p></blockquote><p></p>
[QUOTE="Rich M-37, post: 42662, member: 4397"] Shotym2, I had a engine run a way problem with my 873, it turned out to be the diaphram in the fuel pump. It as a scary situation, and possibly a costly one. The oil level in the crankcase raised up to the level of the breather and started to burn the oil and fuel mix. Also engine oil dillution can be a problem. Keep an eye on you oil level. Rich M-37 [/QUOTE]
Verification
Post reply
