Well, assuming the fuel filter isn't 20 years old, or your fuel isn't 50% mud, you should be able to pump the primer bulb and get fuel out the vent screw on the top of the fuel filter. I pump the primer bulb until it's hard, then hold it squeezed while opening the screw with my third hand. Once fuel and air is expelled from the screw and the bulb goes flat, I hold the bulb flat until I get the screw retightened. Repeat a few times and you should then be getting only fuel out of the vent screw. Then, in your case, pull the inlet line to the high pressure injector pump near the top of the engine. You should be able to pump the primer bulb and see fuel squirt out of that line. If so, then you know you have fuel to the injector pump. I can't remember where the lift pump is in the line, but I suppose there's always a chance the rubber diaphragm in it could have ruptured and when you pump the primer bulb you're pumping diesel directly into the oil pan. Those are about $50 or a little more from Bobcat (I'd stay away from the $40 ones from Amazon, made in China), and I would recommend changing it out as a preventive measure since your machine is close to 20 years old. If the diaphragm ruptures or splits, you could pump diesel into the oil pan for a long while without knowing it (except you'll seem to be gaining oil). Once the level gets high enough, you could encounter a runaway engine, which could be disastrous. Enough for now. Let us know how it's going. And if you have fuel to the injector pump and it still won't run, we'll discuss the fuel shutoff solenoid.......
---Bobbie-G
