So I've been lurking for a long time and finally have come across something I haven't been able to find any info on. We have an 873 turbo that cant keep it up (the arms that is). The machine works fine in all other respects. Its just when you lift the arms up in the air they start falling the moment you let off the pedal. I have done some trouble shooting and this is what I know so far. The problem is not in the linkage or adjustment. The valve doesn't have any scratches or heavy wear. I do not believe the cylinder seals are the problem due to the fact that if you shut the machine off with the arms in the air they still sink slightly but then stop (I would figure if the seals were shot the arms would just continue to sink as the pressure in the cylinder equalizes). With the arms in the air and the machine off the emergency release does let the arms drop when activated. When you let go of the emergency release the arms continue to fall briefly but do come to a stop after 2 or 3 seconds. I'm kind of at a loss here. What would let the arms continue to drop after the emergency release is shut off but then eventually come to a stop??? I'm almost bald from scratching my head... do any of you have any ideas on this?
