873 trouble light
kls
My buddys 873 has a light coming on today its a ! With a diamond around it. The machine will start and then stall any ideas? Thought might be a fuel shut off solonoid? Thanks kyle
I'm guessing there is a "BEEP BEEP BEEP" that goes along with it. It is setting a code. When it does it, push and hold the headlight botton until the code appears. I'm thinking it is going into shut down for something. Bad fuel solenoid will do one of two things on a duetz, not start at all or not shut off. Never heard of run then die. Most likely a bad sensor. If the machine has no hyd functions, it blew the drive belt and is setting a low charge pressure code, which will cause shutdown.
