Bobcat Skidsteer Forums
873 G series HELP
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 99974" data-attributes="member: 82"><p>The test on the injectors was a good idea, you loosen the fuel line and it takes that injector out, so if there is no change, that is the issue.</p><p>I don't see any damage if the valves need adjusting, they need to be really out to be damaged, and i'd suspect it would be running bad, if at all if they were damaged.</p><p>It's worth a try, if something was really wrong, it would be running bad all the time i'd think.</p></blockquote><p></p>
[QUOTE="Tazza, post: 99974, member: 82"] The test on the injectors was a good idea, you loosen the fuel line and it takes that injector out, so if there is no change, that is the issue. I don't see any damage if the valves need adjusting, they need to be really out to be damaged, and i'd suspect it would be running bad, if at all if they were damaged. It's worth a try, if something was really wrong, it would be running bad all the time i'd think. [/QUOTE]
Verification
Post reply
873 G series HELP
