Bobcat Skidsteer Forums
873 Bearing replacement
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 48211" data-attributes="member: 82"><p>I usually just loctite the threads, put a spanner in the chain case and with a bar with a plate welded on it with holes to suit the axle studs, i haul on it. I don't know what torque i get, but its really tight and the loctite holds it there.</p><p>Check for axle end float. It should not move in or out. If so, you need to machine that amount from the inner portion of the washer to take up the slack. Check all the axles, if they move a lot, you may need bearings there too.</p></blockquote><p></p>
[QUOTE="Tazza, post: 48211, member: 82"] I usually just loctite the threads, put a spanner in the chain case and with a bar with a plate welded on it with holes to suit the axle studs, i haul on it. I don't know what torque i get, but its really tight and the loctite holds it there. Check for axle end float. It should not move in or out. If so, you need to machine that amount from the inner portion of the washer to take up the slack. Check all the axles, if they move a lot, you may need bearings there too. [/QUOTE]
Verification
Post reply
