Bobcat Skidsteer Forums
Bobcat Compact Track Loaders
864 turbo problems
Reply to thread
Message
<blockquote data-quote="7LBSSMALLIE" data-source="post: 51957" data-attributes="member: 6879"><p>sorry dude cant but will pull tomorrow and see if i cant get it ou ther without conlicting intrests. ? do you have the ribbed stick and are any missing. new is smooth. i hope you untedrstand my position . s/vc info is protected for obivious resaons. for instance folks crying warrenty on 25 yr old units. the beauty of it is the info is not buried from svc techs. a prime example is youe unit if you brought it in i would no the previous history. of the deutez. saving t/s time and parts and labor .if every issue of all units was posted. to public you can imangine? not all units were affected, dealer personal should be up to date, and once again turbo faliure is rare. you may an underlying cause. from description i would suspect an oil supplly problem. that being said (you did state that turbo was bad) my experiance. point to head gasket. i have seen 2500.00 $ turbos replaced for no reason, other than misdiagonses it makes me sad; pull and inspect glow plugs if she is pumping oil into cyl.s you will see it here.</p></blockquote><p></p>
[QUOTE="7LBSSMALLIE, post: 51957, member: 6879"] sorry dude cant but will pull tomorrow and see if i cant get it ou ther without conlicting intrests. ? do you have the ribbed stick and are any missing. new is smooth. i hope you untedrstand my position . s/vc info is protected for obivious resaons. for instance folks crying warrenty on 25 yr old units. the beauty of it is the info is not buried from svc techs. a prime example is youe unit if you brought it in i would no the previous history. of the deutez. saving t/s time and parts and labor .if every issue of all units was posted. to public you can imangine? not all units were affected, dealer personal should be up to date, and once again turbo faliure is rare. you may an underlying cause. from description i would suspect an oil supplly problem. that being said (you did state that turbo was bad) my experiance. point to head gasket. i have seen 2500.00 $ turbos replaced for no reason, other than misdiagonses it makes me sad; pull and inspect glow plugs if she is pumping oil into cyl.s you will see it here. [/QUOTE]
Verification
Post reply
864 turbo problems
