Bobcat Skidsteer Forums
863 traction lock malfunction
Reply to thread
Message
<blockquote data-quote="Jimmy192" data-source="post: 19651" data-attributes="member: 2103"><p>Just wanted to let you know that I think I found the problem on the tac lock malfunction. It seemed the voltage regulator was defective and allowing the voltage to creep up to 17 to 18 volts. So, I guess the BICS was just doing it job and reporting the over voltage.</p><p>Thank you Tazza for your suggestions and taking the time to help.</p><p>Jimmy</p></blockquote><p></p>
[QUOTE="Jimmy192, post: 19651, member: 2103"] Just wanted to let you know that I think I found the problem on the tac lock malfunction. It seemed the voltage regulator was defective and allowing the voltage to creep up to 17 to 18 volts. So, I guess the BICS was just doing it job and reporting the over voltage. Thank you Tazza for your suggestions and taking the time to help. Jimmy [/QUOTE]
Verification
Post reply
