Bobcat Skidsteer Forums
863 Tilt and Lift not working
Reply to thread
Message
<blockquote data-quote="Axel" data-source="post: 81977" data-attributes="member: 11648"><p>Ok, here's some new info: LIFT seems to work with no problems. but the moment I use TILT both become locked out. today I did some more harness cleaning and checking wiring(looks good), fired her up, and started by using JUST LIFT for a bit. As soon as I moved the TILT I lost both this time BEFORE the TILT even had a chance to move. (usually the tilt would move a little before locking out) Then I turned on BUCKET LEVELING and used the LIFT It worked fine(the tilt adjusted accordingly as I lifted the arms every time) got locked out the moment I tried to JUST TILT I'm hoping this narrows things down? I have noticed that the mounting bolts(round head hex) for the tilt hand controller(right side) are sticking out about an eighth inch from both sides(allowing the controller to have some play) but they will not budge in or out. looks like they've been this way for a very long time since the threads on the bolts are well worn down. the wire sheath that goes past the controller into the handle has some tares in it but the wires seem fine. can I test the controller somehow without taking it out?</p></blockquote><p></p>
[QUOTE="Axel, post: 81977, member: 11648"] Ok, here's some new info: LIFT seems to work with no problems. but the moment I use TILT both become locked out. today I did some more harness cleaning and checking wiring(looks good), fired her up, and started by using JUST LIFT for a bit. As soon as I moved the TILT I lost both this time BEFORE the TILT even had a chance to move. (usually the tilt would move a little before locking out) Then I turned on BUCKET LEVELING and used the LIFT It worked fine(the tilt adjusted accordingly as I lifted the arms every time) got locked out the moment I tried to JUST TILT I'm hoping this narrows things down? I have noticed that the mounting bolts(round head hex) for the tilt hand controller(right side) are sticking out about an eighth inch from both sides(allowing the controller to have some play) but they will not budge in or out. looks like they've been this way for a very long time since the threads on the bolts are well worn down. the wire sheath that goes past the controller into the handle has some tares in it but the wires seem fine. can I test the controller somehow without taking it out? [/QUOTE]
Verification
Post reply
