I am going to use my 863 this winter. Temperatures down to -15C. In the summer the engine runs very cool. I am thinking with winter use it will be even cooler. Is there a way to block the oil cooler or reduce the airflow over the cooler to increase engine temperature? Do you think placing some heavy canvas over the cooling rads would reduce the air flow? Also do I need a heat pad on the hydraulic tank to warm the oil prior to start. I have a oil pan heater and I bought a magnetic heater to supplement the oil pan heater. Any other hints for winter operation? I will not be putting the unit in a warm garage overnight.
