D DanielK New member Joined Sep 13, 2013 Messages 1 Sep 13, 2013 #2 Fuel is leaking into the bottom of the bobcat. What would likely be the cause.
OldMachinist Well-known member Joined May 24, 2006 Messages 2,748 Sep 13, 2013 #3 Check the rubber fuel lines, priming bulb, vent screw loose on filter housing and drain fitting on filter.
L lschilling New member Joined Oct 11, 2013 Messages 2 Oct 11, 2013 #4 Wouldnt hurt to check the top of your tank where the main fuel suction line goes in. I had fuel coming right out the top of the tank around the rubber grommet that the line seals to the tank with.
