As of right now, it is not able to start on it's own. When it will not start, this is what it does. So, this machine will crank over for about 3 seconds, before it will no longer crank / attempt to start. You have to turn the key off before it will crank over again. But, even after trying to start again, it will not start. When it stops cranking over, it seems as if the computer is interfering with the engine cranking. Even with a battery charger, it does the same exact thing. All fluids are good. New battery. Good cables & connections. Obvious signs of fuel smoke coming from the exhaust pipe.
