Bobcat Skidsteer Forums
863 hydro leak ????????????
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 59369" data-attributes="member: 82"><p>There should be holds cut in there to allow it to drain, but they usually get plugged up. I assume you are talking about the rear parts near the drive motors full of water?</p><p>Glad you drained the chain case, you don't water in there! Give it a good clean and fill with fresh oil.</p></blockquote><p></p>
[QUOTE="Tazza, post: 59369, member: 82"] There should be holds cut in there to allow it to drain, but they usually get plugged up. I assume you are talking about the rear parts near the drive motors full of water? Glad you drained the chain case, you don't water in there! Give it a good clean and fill with fresh oil. [/QUOTE]
Verification
Post reply
