863 Hydraulic Coupler
KAG
Is the coupler that is attached directly to the machine exactly the same as the couplers on the attachments I connect to it? The reason i ask is I tore the female off last night working in trees with the grapple buckle (the end is gone where the lock ring is). I would compare the two but I can't find the fitting that got tore off, it was dark. I know the attachment coupler is a 3/4 on the grapple.
I'm pretty sure they are the same. If you are worried, take the other coupling off the grapple down to the hydraulics shop and get it matched. I think some flat faced ones are a bit fussy, but the regular style are pretty well a standard between brands.
Do you have the flat faced couplers or the older pioneer, these machines can with?
The flat ones uses a #12 o ring boss female. (12 orb female) which stands for 12/16” or 3/4“ thread, where if I remember right the Pioneer ones I took off had a 10 orb female. I had to change the bulkhead fittings to the larger size. But after that they match any of my attachments from Bobcat,
I replaced it and it was the same on my 863. It has flat faced ones.
