Bobcat Skidsteer Forums
863 bucket wont move intermittently
Reply to thread
Message
<blockquote data-quote="Bobcatdan" data-source="post: 83978" data-attributes="member: 7339"><p>Tilt is the top, lift is bottom. Switch the connectors and run it until it throws a fault. Your controls will be backwards. If the code switches to a lift fault, you know it is an acturator. One thing, if you are getting a "acturator out of neutral" code, that may very well indicate a sticking spool, not the acturator.</p></blockquote><p></p>
[QUOTE="Bobcatdan, post: 83978, member: 7339"] Tilt is the top, lift is bottom. Switch the connectors and run it until it throws a fault. Your controls will be backwards. If the code switches to a lift fault, you know it is an acturator. One thing, if you are getting a "acturator out of neutral" code, that may very well indicate a sticking spool, not the acturator. [/QUOTE]
Verification
Post reply
