853h wont start
Superfly
Its showing an es-6. Engine speed no signal. I started machine to warm it up while on the trailer as i was driving to the jobsite because it starts hard when its cold. When i got to the site, it had died showing me this code. I thought maybe it had run out of fuel but that wasnt the case. Any help is appreciated. Thanks
I also removed the sensor in the flywheel housing and cleaned it off because it had some dirt build up on it thinking it would help but it didnt.
Its possible the sender is bad, or even the magnet may have come out of the fly wheel?
i talked to the stealer and they arent sure so i ordered a new sender. I didnt know there is a magnet on the flywheel, im going to have to look into that also. Im also getting a fuel 3 code which isnt a huge deal. and i cannot seem to find where the fuel sender is.
It should be behind the pump, in a hard to reach position. Most are located here on the right looking from the cab side. If you replace the sender, be careful not to bend it, they snap. Its not a fun job getting it in or out.
