853H problems
kosmidis
Hello to all from GREECE....i have a bobcat 853H s/n 509711348 year 1991-1992 and i have some problems with the boos system ..... from the panel the only thing that work is the beeper . Can i disconnect it and put some analog instruments for the basics oil, temp , etc . Did someone try it thank you for your time.....
You can't just disconnect and reconnect a different cluster as far as i'm aware. If you are good with wiring/clectrics you could do it, but it will take a lot of work.
thank you ...Can i cancel the.... (computer-brain) ?
i did see it done once. did not make me happy when it came back in for elect issues.(try and t/s that) let alone the fact that saftey issues were bypassed as well . please do not modify. life and limb cannot be priced tagged. youre issue is probbaly nothing more than one bad sender, the bulb in the led can be cleaned so you can see it again. and a preprogramed boss is still avail.(was state o art) so was attrie.
ok today after 4 hours i take out the engine and is one thing with the hydraulic pump. I dont know if i try it again now i will start fix the engine because there is no compression so i'll change the rings off the pistons i will take out and the control panel to see if the led is off. I'll post and somme photos....
If you are diving into the engine, make sure you get the head checked for cracks too. It can be a cause of low compression too, they like cracking between valves.
Please do take pictures and post what you can.
Here are somme photos ...
http://imageshack.us/photo/my-images/51/cleannotank.jpg
http://imageshack.us/photo/my-images/853/monitor06.jpg
http://imageshack.us/photo/my-images/685/monitor07.jpg
http://imageshack.us/photo/my-images/809/petroltube02.jpg
http://imageshack.us/photo/my-images/856/petroltube01.jpg
http://imageshack.us/photo/my-images/163/petroltubeoups.jpg
http://imageshack.us/photo/my-images/23/monitor04.jpg
http://imageshack.us/photo/my-images/705/monitor03.jpg
http://imageshack.us/photo/my-images/85/monitor02.jpg
http://imageshack.us/photo/my-images/94/monitor00.jpg
http://imageshack.us/photo/my-images/585/engineul.jpg
http://imageshack.us/photo/my-images/820/bobcatback00.jpg/
http://imageshack.us/photo/my-images/171/bobcatfrominside.jpg
something went wrong ....
