853 wont start or even turn over
timcat
Hi all, I have recently aquired an 853. It ran perfectly for a full day last week. When i tried to start it today there was nothing. When the ignition key is turned it beeps as usual but then nothing happens. The display shows glo 5 momentarily and then returns to the normal running hours display. There does not appear to be any other warning lights or error codes on. Tried using a new charged battery with no luck. The hydraulic resevoir is a bit low but this shouldnt stop the engine starting should it? I am new to this machine so any help would be greatly appreciated. Hopefully its something simple. Cheers, Tim.
Tim
Its not with the hydraulics.
Check your fuse panel to be sure all the fues are good.
There are also 4 spdt relays beside the fuse. (black box about 1“ cubed with 5 blade terminals where the wire harness attaches) They have labels beside them indicating the function. Try swaping them around, but keep track of which one went where. If they are the problem the trouble may move from starting the engine to the parking brake won't release, or no glow plugs etc.
Worse case turn the key on and check the wire to the injection pump for power. This wire loses power to shut the engine off. If it has power then it is just a matter of getting the engine to crank.
With the operator in the seat for safety, and the key on, take a jumper wire and go from the large terminal on the starter to the small terminal, if the starter, battery and main power wires are good the engine will crank over and start.
Tim
Thanks for the advice Ken. My first thought was fuses but as i am new to the machine i could only find 4 fuses attached directly to the wiring harness just near the battery, is there another fuse box somewhere that i am missing? I will check the injector pump power and if need be connect the starter terminals like you said. Thanks again for the reply. Tim.
No those should be he only fuses and on my non boss 853 the relays where right there too. Sounds like you have the Boss digital guage panel. My 1993 753 had this an had relays in the harness under the cab about where the operators left shoulder was, but underneath, the boss tin control box was there nearby also. So look around some. The relays wear out just like a starter solinoid does (clicks but won't make contact to crank) so try swapping these too.
yeah i found the boss control box under the cab but couldnt see any relays there i will check again though. from doing a bitof research sounds like the boss system causes more problems than it prevents. Tim.
