Bobcat Skidsteer Forums
853 tilt
Reply to thread
Message
<blockquote data-quote="BubbaDirt" data-source="post: 18575" data-attributes="member: 835"><p>I changed out the spool seals with pump in place. No way would I try to remove pump. Hardest part is correct order and direction of seals and springs. I took spools to dealer and parts man stacked parts in order. A week later I had to re-do one spool as I blew out seals. I was spreading stone with bucket tilted verticle when I bounced and dug teeth in ground. Yes, I knew better</p></blockquote><p></p>
[QUOTE="BubbaDirt, post: 18575, member: 835"] I changed out the spool seals with pump in place. No way would I try to remove pump. Hardest part is correct order and direction of seals and springs. I took spools to dealer and parts man stacked parts in order. A week later I had to re-do one spool as I blew out seals. I was spreading stone with bucket tilted verticle when I bounced and dug teeth in ground. Yes, I knew better [/QUOTE]
Verification
Post reply
853 tilt
