Bobcat Skidsteer Forums
853 charge pump psi
Reply to thread
Message
<blockquote data-quote="cnord" data-source="post: 46292" data-attributes="member: 5146"><p>With your serial number break, your charge relief setting is set at 230 psi. So for the most part your charge pressure should not be too much lower than that for your pump to work decent.</p></blockquote><p></p>
[QUOTE="cnord, post: 46292, member: 5146"] With your serial number break, your charge relief setting is set at 230 psi. So for the most part your charge pressure should not be too much lower than that for your pump to work decent. [/QUOTE]
Verification
Post reply
853 charge pump psi
