853 bics problem
jackxm
My bobcat wont move, when I turn on the key I usualy get a beep and then a clunk now no clunk I have no lights on the system control not even the power light. I checked the fuses and they are good. What will keep the lights off even power light? any and all help would be deeply appreceiated.
You sure the battery is still good? they do just fail.
The fuses may be ok, but check the fuse holders, they get corrosion from time to time and cause issues.
battery is new and good starts fine , I checked wires below the fuses with key on by probing wires all have 12volts on both wires I have run into this problem in the past and corrected it. will a bad sensor keep the power light off on the system control?
problem solved three wires on cab harness were broken don't know how it happened could be critters
Excellent!
I'm still amazed critters like the taste of wires, they don't look or smell very tasty to me....
