843 shudders when turning
donald73d
When I use the left lever to turn the machine it kind of shudders (bangs back and forth while turning). If I use only the right level it does not do it or just a tiny bit. its full of hydraulic fluid.
Probably 1/3 throttle, unsure about RPM, no tach. Maybe 1/4. I tend to run the machine at a low throttle. Maybe I should not.
Give it 1/2 to 3/4 and see what it does. Too low and you will feel it biting at your steering levers.
