Have worked on several 843s they are very good machines. Air will self bleed quickly so start looking for a problem. Open lines from the charge pump to the feed lines at the hystats and see if you have any flow. Should have a two section hyd pump half works the lift and tilt and half charges the hystats. If the charge side is bad or weak you made ruin a newly built hystat. My guess would be charge pump is bad but always test to make sure. Hope some of that helps.
