843 left drive lever wont go forward
schut farms
I had some noise on the left side drive and thought it might be the drive motor. Jacked entire bobcat off the ground because I wanted to make sure it made the noise with no load and was going to switch drive motors side to side to verify that was the problem. Previously to taking it apart sometimes the left drive lever would kick back forcefully when in the forward position. Jacked it up and sure enough it made the noise still but it kicked back and now won't go forward at all. Took linkage off and it won't even move the shaft in the pump. Any ideas on where to start? Thanks
